Common Problem - Oil Seal Housing Warp
Posted by Red Raider on November 21, 2000 at 17:12:34 from (208.188.19.123):
I've been into two Farmalls and a Cub Low Boy now, and all three had a warped rear crankshaft seal retainer. I suppose after years of cold and hot cycles of the engine causes the aluminum housing to warp around the cap screws. A cast iron housing would have been an engineering improvement. Just an observation I've not seen on the Farmall board.
Post A Followup
: Re: Common Problem - Oil Seal Housing Warp
