Re: 1940 m carb
Posted by wayne in mn on June 13, 2013 at 11:56:46 from (64.118.12.213):
In Reply to: 1940 m carb posted by l mika on June 13, 2013 at 11:10:27:
Just get a kit for an M; makes no difference if fuel or gas burner.
Be careful separating the top from the bowl so you don't break off the idle air jet. Lift straight up; do not rotate or slide the top sideways.
