Re: Where to check cub lowboy hydraulic fluid.
Posted by screwstick on June 14, 2013 at 18:39:04 from (174.24.2.45):
In Reply to: Where to check cub lowboy hydraulic fluid. posted by mdm1 on June 14, 2013 at 17:08:38:
Is this an older offset LoBoy or a newer Numbered Series LoBoy (154, 185, or 184)?
Older offset, then like the fellas said above. Newer Numbered Series, then the fill plug is on the rear cap of the transmission. On either style, if the fluid runs low soon after filling it up, check the engine oil for it being overfilled. The pumps will leak fluid into the crankcase.
