Re: farmall 460 hydraulic fluid moisture prevention
Posted by Bob M on June 15, 2013 at 08:17:00 from (74.67.186.88):
In Reply to: farmall 460 hydraulic fluid moisture prevention posted by farmalllh on June 15, 2013 at 07:01:30:
Exactly what Tractor Vet says.
Incidentally adding IP (or any other) alcohol DOES NOT keep the moisture out! Rather it mixes with collected water and helps keep it dispersed in the oil. This makes the water less likely to settle to the bottom and thus harder to drain.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
