1455xl
Posted by C Clark on June 16, 2013 at 02:44:08 from (222.152.98.208):
Hi
Looking a buying a German built 1985 International 1455xl tractor. Took the tractor for a test drive the other day and noticed it had two pressure gauges in between the rev counter and warning lights gauges. One of these is clearly engine oil going by the pressure and how it fluctuates with engine revs, the other only reads very low (around 10 psi) and I'm not sure what its for. In the operators book it only shows one gauge which is for air pressure when pneumatic brakes are installed which it does not have. Both are VDO gauges which is the same as the rev counter etc and look original. The tractor does have a turbine clutch. My guess would be a pressurised lubrication for the transmission. Any one know?
Thanks Cameron
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
