Re: M Transmission shifter adjustment
Posted by rustred on June 16, 2013 at 08:09:29 from (74.214.152.80):
In Reply to: M Transmission shifter adjustment posted by FarmallShifter on June 15, 2013 at 07:27:53:
if you had the trans. apart maybe the gear got put in backwards. just my thought as dont know what all you did to trans.if all rails are in neutral then if gear is backwards it will hold it in a gear.
