Re: Anti-Freeze in Oil
Posted by Dennis K (WA) on June 16, 2013 at 08:28:52 from (24.21.78.195):
In Reply to: Anti-Freeze in Oil posted by WI-Ed on June 16, 2013 at 03:57:46:
Could be a head gasket but not necessarily.
Before any disassembly you should pull the pan and maybe valve cover, pressurize the cooling system and check for signs
of the leak. Could be from the bottom sleeve seals as mentioned.
If you remove the head first you have no way to test the system and may replace the gasket and still have the problem.
As mentioned, bars leak may plug up a small leak.
good luck with it
Dennis
