Re: Anti-Freeze in Oil
Posted by Tom Fleming on June 16, 2013 at 09:05:49 from (67.20.233.75):
In Reply to: Anti-Freeze in Oil posted by WI-Ed on June 16, 2013 at 03:57:46:
BArs leak works fine in a thermosyphon system. However, it does require that you get it up to temp BEFORE you put it in, then run it a bit afterwards.
I have used it on an A, a BN, an F20, F30, and a REgular, all with great success.
Warm it up, dump it in, then run it up to temp for at least 30-60 mins. problem solved.
