Re: Farmall Bn Mag wiring
Posted by John T on June 16, 2013 at 17:21:08 from (216.249.76.176):
In Reply to: Farmall Bn Mag wiring posted by dougct on June 16, 2013 at 17:10:28:
Im not surprised it charged, the F on the Cutout consisted of a resistor to frame ground and if the gennys F was also wired to a LHDB light switch, that placed yet another resistor (if in Low) to frame ground in paralell for an even higher charge rate (less net resistance if 2 in paralell). If the LHDB was in High Charge then the field was essentially dead grounded for the highest charge rate possible.
The F on a cutout relay is for a tractor with no LHDB light switch and lights so the genny can still charge cuz the Field has a resistive ground. If it has the LHDB switch the gennys field wires to it so it gets a resistive ground for low charge and a dead ground for high charge.
I would only use one device for charge control so if it has a LHDB switch Id use it and NOT the relays F terminal.
If it has a mag that generates its own power with no connection to or reliance on any battery or charging system.
John T
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
