Re: regular piston
Posted by Ron W on June 16, 2013 at 19:50:49 from (24.247.83.82):
In Reply to: regular piston posted by doug st john on June 16, 2013 at 19:34:26:
On the farmall regulars, f-30, w-30 and 10-20 you can pull the piston out the bottom. You need to remove the oil pan, take off the bearing cap, rotate the crank as you pull the piston out the bottom.
For reassembly, there is a chamfer on the bottom of the sleeve to aid in putting the piston (rings) in from the bottom.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
