Odd problem with a Farmall 340 part 2
Posted by old on June 17, 2013 at 10:31:03 from (209.86.226.57):
Well I found the problem and yes it was odd. Distributor drive gear is bad and lost a couple of teeth. The reason it was so hard to figure out was it would spin some times and then stop spinning which would in turn cause it to go out of timing and do odd things. Now to find a gear or maybe take a distributor off an H I have that I do not use and at least have the 340 running.
