Posted by Owen Aaland on June 17, 2013 at 15:52:01 from (216.47.35.170):
In Reply to: 806 D Alternator posted by Bob M on June 17, 2013 at 09:58:29:
Bob M said: (quoted from post at 12:58:29 06/17/13) Filo -
You will be better off using a 3-wire Delco (10SI series) alternator. Will cost less, charge better at startup and is less likely to run down the battery if the tractor is not started for long periods. Also will properly operate your idiot light (a 1-wire alternator will not).
Wire up the 10SI as follows:
- Large wire to the alternator BAT (output) post
- Relocate wire from the #4 terminal on the old VR to the #1 aux terminal on the new alternator.
- Connect a jumper from the new alt output post to the #2 aux terminal.
Cutoff/tape all other wiring at the (unused) VR plug.
This is what you currently have for wiring on your tractor.
The only problem you may encounter using Bob's solution is that if your light bulb fails the alternator will not start to charge. A resistor of equal or greater value than the light bulb connected between the #3 and #4 wires at the regulator will overcome this problem.
The #4 wire can be connected to the #1 or F terminal wire at the old regulator and then use that wire to connect to the #1 terminal on the alternator.
This post was edited by Owen Aaland at 22:07:59 06/17/13.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
