Re: 544 hudraulic system
Posted by Janicholson on June 17, 2013 at 20:03:34 from (74.60.94.18):
In Reply to: 544 hudraulic system posted by Tim (NY) on June 17, 2013 at 05:46:59:
Two usual methods are to use the power steering by turning it to the stops left and right till it acts correctly. then use the three point up and down to its limits maybe 10 times. If you use A Loader, operate it through its range. (be careful to assure that it cannot drop on anything if an air bubble is in a cylinder, usually they are just spongy). Use the remotes if equipped to assure complete purging of the air. If it is not catching prime, Put about 15PSi into the reservoir (no more than that) and operate the controls as above. Jim
