Re: 806 D Alternator
Posted by Jon Hagen on June 17, 2013 at 22:54:09 from (69.26.17.61):
In Reply to: Re: 806 D Alternator posted by Jon Hagen on June 17, 2013 at 22:43:01:
I should have added, connect the original heavy Bat wire in the original tractor harness, plus the red #2 wire from the new regulator plug, to the "BAT" stud at the rear of the new alternator.
My advice is assuming that you do have a Delco SI series "1 wire" alternator that uses the regulator plug shaped like this [- -].
Good luck, that SI series Delco alternator with the built in solid state regulator is much more reliable and has much better voltage control than the original Delco 10 DN with the external mechanical regulator.
