Re: Zenith Carb on 1945 Farmall A
Posted by gene bender on June 18, 2013 at 03:07:19 from (207.177.56.180):
In Reply to: Zenith Carb on 1945 Farmall A posted by Stevie J. Mote on June 17, 2013 at 13:11:11:
First are you sure the carb is original. If it is there is a round plate on the top brass circle with rivet in the center that plate will have a #. If there isnt one you have a replacement of some kind. Is there a choke lever on the outside little spring type thing. Which kind of a kit do you want just gasket and needle and seat. Why do you think it needs a rebuild. Sometimes you need small drill bits to clean the idle circut compressed air dont always get the passages entirely clean.
