Pump most likely needs repair as retainer ring is failing and plugging the one way check valve at tank bottom return line. Test by leaving the 2 timing cover screws loose so fuel can leak from housing, if it runs then the pump needs repair and fitting cleaned or replaced. High housing pressure will shut down this type pump.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
