Re: Is this a Farmall hand crank?
Posted by sflem849 on June 18, 2013 at 07:49:34 from (69.197.84.39):
In Reply to: Is this a Farmall hand crank? posted by Russ from MN on June 18, 2013 at 07:37:02:
Don't say that around here!!! You can't even crank an F series here on YT. :lol:
