Re: Farmall A Oil Filters (Tall Short)
Posted by Lmack on June 18, 2013 at 09:28:03 from (24.131.50.165):
In Reply to: Farmall A Oil Filters (Tall Short) posted by Stevie J. Mote on June 18, 2013 at 08:01:40:
IH changed to the "short" filter to make room for the oil tubes from the live oil pump at the front of the distributor to the hydraulic assembly under the fuel tank (A to SA). If you have the short filter you most likely have a Super A.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
