Re: Farmall A Oil Filters (Tall Short)
Posted by Owen Aaland on June 18, 2013 at 10:37:43 from (216.47.35.170):
In Reply to: Farmall A Oil Filters (Tall Short) posted by Stevie J. Mote on June 18, 2013 at 08:01:40:
The change in filter height (M changed to smaller diameter) happened when IH change the filter material from a wire mesh screen to a paper filtrate. The new filter was much more efficient so that the shorter filter did a better job of filtering the the older, longer one.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
