If you have a rebuild shop near by use it. If you do not rebuild starters on a regular basis then I would not recommend you start now . . . unless you are up for a challenge. Are you sure the starter was not "locked", that is bound up with the flywheel in such a way that the engine will not turn. If you have a hand crank try cranking the motor. If not put it in high gear and try to rock the tractor using the rear wheel. If the fan does not move you have a "locked" starter. The C113 and C123 engines were bad to lock up on start with nothing wrong with the starter. Get back to us if the engine is locked up and someone will tell you how to fix the problem.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
