Re: regular piston part 2
Posted by James Williams on June 19, 2013 at 05:54:20 from (74.46.219.228):
In Reply to: regular piston part 2 posted by doug st john on June 18, 2013 at 18:42:27:
Doug,find someone with a good sleeve puller,they clean up and go in easy,Its not a bad job.
jimmy
