Re: Bars leak
Posted by Janicholson on June 19, 2013 at 10:08:36 from (199.17.6.60):
In Reply to: Bars leak posted by WI-Ed on June 19, 2013 at 09:07:35:
When the tractor is cool, pour it in, then run it to temp.
Use the brown goopy stuff for radiator leaks. Jim
