9/10 volt drop from battery to resistor could indicate a corroded ignition switch or bad wiring.
The coil appears to be new. Are there markings on it such as "12 volt external resistor required" indicating that it needs the resistor or could it be a true 12 volt coil that needs no resistor? I've also seen 12 volt conversion kits with a resistor with too much resistance. It should be about 1 1/2 ohms
Output of coil to distributor should read near battery voltage with points open, near zero with points closed.
It also appears to me that the wires on top edge of alternator may be reversed. #2 on right should loop down to big output stud. #1 on left should connect to the ignition switch with a diode in the line to prevent engine continuing to run with switch turned off?
One check would be to disconnect wire from + side of coil and run temporary wire direct from battery + and see if you get spark. This will bypass switch, resistor and that section of wiring.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
