Re: farmall h bull gears
Posted by CharlieU on June 19, 2013 at 19:11:56 from (208.123.2.74):
In Reply to: farmall h bull gears posted by charlespretzer on June 19, 2013 at 18:37:44:
If you want to reverse the bull gears you need to switch them to the other side of the tractor. I do it all the time when I have both axles out. If you also switch the bull pinions you would then be using the unworn surface of the tooth. good luck, charlie
