The hot post on the starter will have continuity to ground through the starter. The internal resistance of the starter is very low so it would appear to be almost a dead short. That is why the current draw is so high when voltage is applied to the starter cable. This continuity should exist all the way to the starter side if the starter switch. The other side of the starter switch back to the battery should not have continuity to ground unless there is another switch left on. If either the ignition switch or the light switch were on they would provide a path to ground.
Instead of checking continuity to ground it will be much easier to find your problem bu checking voltage drop under load across each part of the system. There should be no drop along a cable. A connection should have no more than .1 volt. A switch should have no more than .2 volts drop.
With all that you have done I would take a close look at the starter switch. Check the voltage drop across the two terminals while trying to crank the engine.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
