Re: Farmall starting circuit
Posted by Janicholson on June 19, 2013 at 20:51:38 from (74.60.94.18):
In Reply to: Farmall starting circuit posted by Muddriller on June 19, 2013 at 19:13:45:
Some starter switches are no good, some are good but do not touch the "hot post" when used. There are several types of starter switches on Ms. If it is a push button on the light bar, or down low for foot or rod push, check that there is voltage getting to the starter side of that switch. If it is a starter mounted switch, the internal moving part may not touch the hot stud on the starter. Use a thin rat tail or chain saw file to elongate the holes to allow closer contact. Jim
