Re: H distributor slop
Posted by Duner Wi on June 20, 2013 at 04:48:12 from (216.226.80.242):
In Reply to: Re: H distributor slop posted by Janicholson on June 19, 2013 at 20:07:28:
Depending on the wear on the shaft I have purchased correct OD bushing ans fitted the inside so it just barely slides over the shaft. If shaft is not worn too much your might be ok. Remember .001 at the shaft gets you much more at the points gap. Probably 3 or 4 times. That varies due to distance from rubbing block to points contacts.
