Re: Farmall M No spark Trouble shooting guide
Posted by Nate V. IA on June 20, 2013 at 09:17:59 from (216.51.200.72):
In Reply to: Farmall M No spark Trouble shooting guide posted by Nate V. IA on June 19, 2013 at 15:08:58:
John T and others
I am an electrical idiot but willing to learn. I set my meter to 200 ohms and tested the ballast resistor, the meter reads 3.0. Voltage ahead of the ballast is 12.8, after ballast is 4.0. The voltage readings vary everytime I check. I bypassed the ballast and am only getting 10 volts to the + terminal on the coil????
The alternator is wired correctly I think, #2 wire goes to + terminal on the coil and when removed it doesnt effect any readings.
The coil is 12v w/o resistor so, the way I understand it, it needs to have a resistor ahead of it.
I am only getting 4 volts to the coil today and had 6v last night.
The points are opening and closing as they should. Test light shows power to the coil + terminal. No power to the - terminal or the high power wire to the dist. cap.
Thanks for putting up with my ignorance.
Nate
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
