Re: Engine Stuck
Posted by Mark58 on June 20, 2013 at 10:45:40 from (68.68.150.215):
In Reply to: Engine Stuck posted by Mark58 on June 20, 2013 at 10:15:07:
Have been using oak and a big hammer and even hyd jack that is how the front sleeve and piston finally came out.I can't even get the rod caps off the center 2 until i get the back one out.I was wondering about trying to heat them up with a torch and see if that will help.
