Re: Super MTA IPTO, what type of oil??
Posted by Owen Aaland on June 20, 2013 at 12:01:05 from (216.47.35.170):
In Reply to: Super MTA IPTO, what type of oil?? posted by sflem849 on June 20, 2013 at 11:20:25:
This is another case where the information in the operators manual is no longer correct. Manuals were printed in advance of the tractor being released for sale. If changes were made during the production run the manuals were usually updated to reflect the changes. If changes were made after the production run, as is the case here, the manuals were not necessarily updated. That results in a lot of manuals not having the correct current information. Reprints of manuals are normally just that, a reprint of the original manual. The result is you can buy a new manual and still not get the correct information.
