Cub fan shroud
Posted by jgstrickland on June 20, 2013 at 12:15:28 from (71.82.36.253):
The two bottom screwheads have been broken off in my supports, can I remove the radiator supports and drill and retap them? Sure I can but has anyone drilled through the front two holes and through the fins of the radiator to drill new holes? Just a thought. This is a 1949 cub.
James
