Re: Engine Stuck
Posted by RustyFarmall on June 20, 2013 at 13:16:13 from (216.248.71.226):
In Reply to: Engine Stuck posted by Mark58 on June 20, 2013 at 10:15:07:
Like someone else already mentioned, the pistons and sleeves are junk anyhow, so wrecking those pistons is not a problem.
Start by drilling a series of holes through the top of the pistons, and then insert a hacksaw blade down through one of the holes and do your best to cut through the piston skirt right up to the sleeve. Might have to do that in a couple of different places. Eventually you will be able to remove the chunks.
