Re: Engine Stuck
Posted by Dave Sherburne NY on June 20, 2013 at 16:19:12 from (50.48.59.69):
In Reply to: Engine Stuck posted by Mark58 on June 20, 2013 at 10:15:07:
third party image
third party image
I don't know about a Super M but when I took them out of a Cockshutt 30, this is what I made to get them out. They came out easy. The bottom of the sleeve has to stick down below the block a little for it to work. The rectangular tube slips up over the rod and pushes on the sleeve. It's made from 2" square tubing, and 3/4" threaded rod. Straddles the engine and just keep tightening the nuts to force the sleeve out You have to put spacers between the top of the block and the 2" square tube that sits on the top. The rectangular tube is 2" X whatever it takes to go over the rod. Pieces welded to the rectangular tube are a slip fit over the bottom square tube to keep it in place while you tighten the nuts. Worked great for me.
