Re: Monroe easy ride seat-Farmall Super A
Posted by Charles Green on June 20, 2013 at 20:00:39 from (70.58.59.161):
In Reply to: Monroe easy ride seat-Farmall Super A posted by Roger N. on June 13, 2013 at 10:22:44:
Roger: You may want or have to remove the seat pivot brackets that the main seat pivot mounts on. The sheet-metal pedal guard will have to be removed to allow access to the nuts holding the bracket screws. There are three slotted head screws holding the back of the guard and two hex head screws at the front. It is not immediately obvious, but removing the two hex-head screws and shooting grease in their holes is the only way to lube the break-pedal pivots and it should be done periodically.
