1. Governor throttle shaft (shaft inside tube between carb. and top of governor housing) may not be engaged properly with throttle shaft in carburetor.
2. See if the brass (or plastic) piece on the end of the carburetor throttle shaft isn't spinning on the shaft.
3. Throttle shaft lever (arm at end of governor throttle shaft) may have broken the pin through it that holds it in place on the governor throttle shaft. This can cause tractor to idle fine and run wide open when moving the throttle lever to a point that causes some movement of that arm.
If you're gonna keep yankin' that throttle lever back and forth, pull it downward so it doesn't drag on the notches. You'll have it wore out before you know it.
AG
This post was edited by AG in IN at 07:16:23 06/22/13 2 times.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
