Re: Throttle twisting
Posted by RustyFarmall on June 22, 2013 at 08:28:55 from (216.248.71.226):
In Reply to: Throttle twisting posted by Jim Paterson on June 22, 2013 at 01:18:35:
You can tinker and adjust, build up the tooth, tinker some more, cuss it 'cause it still misbehaves, or you can spend a little money and buy a brand new unit. Problem solved, and the new one will work so much better than you ever thought possible.
Been there, done that.
