Re: A simple tool to prop up your tractor
Posted by Patrick HMD on June 22, 2013 at 10:32:08 from (75.9.223.209):
In Reply to: A simple tool to prop up your tractor posted by Patrick HMD on June 22, 2013 at 03:22:16:
The stand itself fastens in the same manner to the same IH parts that you would normally attach your drawbar angles too. So all that is already done for you, and those parts are left on the rear axle housing, assuming of course that you are running a normal drawbar.
I didn't take anymore pics or measurements. The flat bar with slotted holes looks to be about 3/8"x4". I would guess the outer pipes to be about 1 1/2" sch 40, no less, and are stitch welded to the FB. I would guess the cross braces to be at least 3/8"x2". Build it strong, don't skimp on material. Better safe than sorry.
HTH
Patrick
'49M
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
