Re: Throttle twisting
Posted by Owen Aaland on June 22, 2013 at 17:19:10 from (216.47.35.170):
In Reply to: Throttle twisting posted by Jim Paterson on June 22, 2013 at 01:18:35:
If the latch tooth is still in pretty good shape on the handle you can put a slight twist in the handle between the tooth and the pivot point. Just enough so that the tooth engages before the rear of the handle hits.
