Re: Farmall H starter
Posted by gene bender on June 22, 2013 at 18:42:16 from (67.55.198.76):
In Reply to: Farmall H starter posted by jim23377 on June 22, 2013 at 15:00:50:
You dont need a new one just get your serviced mitehave a bad ring gear that will lock any starter up because of bad teeth. Remove yours and turn the engine over slow and inspect the teeth on the ring gear. Also bad cables will not turn starter fast enough to enguage good.
