Re: B414 plackard
Posted by caterpillar guy on June 22, 2013 at 19:44:43 from (68.188.235.156):
In Reply to: B414 plackard posted by rosedale123 on June 22, 2013 at 19:11:19:
Used to be able to buy speedometer cable at parts houses. I is just the same as that I think. You had to cut it to length then put the one end on.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
