Posted by Janicholson on June 23, 2013 at 07:29:03 from (74.60.94.18):
In Reply to: Cub carb question posted by charlie M on June 23, 2013 at 06:31:13:
About the only way is to buy a brass fitting that has the same threads as the original, and has a female end matching the fuel line. Cut off a portion of the end of those threads so the threads start just a little bit larger in diameter, Maybe 3/32" shorter. Buy fuel resistant epoxy based sealer (fuel tank leak sealer type material) and use it to glue in the fitting (do not over tighten it, and make sure things are way clean. Let it harden for a Day or more before using. Don"t over tighten the line fitting and hold the new one while doing so. Helicoils usually cannot work in tapered threads. Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
