Hi, remove the thinner plug under the MCV, remove the sring, place a container to catch the oil, start the engine and pull on the remote lever. The divider valve will go in the container. Stop the engine. Check for scratch on the divider valve and smooth with a 400 sand paper. Sometime you have to smooth in the valve bore.CaseIH send a kit to replace the faulty divider valve. Replace the divider valve with the small end up in the bore.Check your filter and change if it"s old, make sure to place the element toward the MCV and the screen in the cover. If the divider is stuck in the bottom of the bore, you have no steering and PTO and in the upper of the bore, you have no hydrolic power.Hope this help. Bernard le mecano Quebec Canada
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
