Posted by Janicholson on June 23, 2013 at 13:45:42 from (74.60.94.18):
In Reply to: Anti-freeze in oil posted by JS Sleds on June 23, 2013 at 13:01:02:
They are dry (in theory) but cracks in the block casting in the bore/s can leak between the bores and the sleeves. Jim With the head off, it is tough to pressurize the water. Putting cool aid colored water (no sugar or sweetner use 5 envelopes of punch) in the block to the top of the block, with the pan off, will allow you to see if it is leaking there. It might take time! Jim
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
