Re: M starter switch
Posted by RustyFarmall on June 24, 2013 at 08:36:02 from (216.248.71.226):
In Reply to: Re: M starter switch posted by D. Slater on June 24, 2013 at 08:22:04:
In my experience, if the push button switch is operated with the pin through the steering support, the switch will be in a slightly different location in the fuel tank support than if the switch is operated with the foot control lever. (Clear as mud?) In other words, if you want to change over the foot operated lever, you will also need to change out the fuel tank rear support.
Another option is go with the cast iron bracket that mounts the starter switch opposite the ammeter/light switch box, on the support column. That option puts the switch up where you can push it with your hand.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
