Re: IH 404 - Fluid from gear shift
Posted by Janicholson on June 24, 2013 at 08:47:38 from (199.17.6.160):
In Reply to: Re: IH 404 - Fluid from gear shift posted by Dravery1 on June 24, 2013 at 08:39:34:
Using the machine often to the point that the oil in the trans gets to temperature, will evaporate the water (mostly). Changing it will make 80% go away. The trans breaths in and out with air temp changes and thus brings in humidity no matter if it has a boot. (the boot is a good idea, I like to use a CVjoint boot as they are made tough and look good.)
Jim
