Re: Surging govenor
Posted by notjustair on June 24, 2013 at 13:10:36 from (174.229.70.3):
In Reply to: Surging govenor posted by d282 on June 24, 2013 at 12:07:36:
I'd go for carb adjustment, too. First time I ground feed with my M it surged badly. While it was grinding I adjusted it - smooth as silk now. The letter tractors like it a little rich, but I think that still sounds like it is lean. You know how they get right when they run out of gas or you haven't turned on the tap? That's what you are dealing with.
