Re: Super A oil change
Posted by old on June 25, 2013 at 08:06:12 from (209.86.226.11):
In Reply to: Super A oil change posted by jeep258goat on June 25, 2013 at 05:51:22:
Just as JR says. No dip stick but has 2 petcocks to check oil level and the full is about center of the hood. If you look under the hood you will see the tube going up and out of the valve cover. Holds 5qt of oil by the way
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
