Generator 12 or 6 volt
Posted by jgstrickland on June 25, 2013 at 15:40:34 from (71.82.36.253):
Hello again,
I am getting closer to finishing up a 1948 Cub and I am at the Generator now. I just purchased a Generator for it with the brackets. It's a Delco Remmy 1101355 8G14 and I am getting a 14v reading off of it. I thought that they were 6V Gennys. Is it possible that someone wired it 12v?
It does have a cut out on it and I have cleaned all the grounds and all the coonections and ran emory cloth through the contacts on the cut out as well. I have a Magneto on the the tractor and jump start it with a 12v battery for now until I figure out which way to go. I disconnect the battery after starting the tractor. What is up? Do I have a cross breed genny or what? Is it working right for a 12v system if so I will go 12v.
Thanks
James
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
