Posted by JimB2 on June 25, 2013 at 16:36:07 from (99.241.76.141):
In Reply to: brakes posted by stephen roberts on June 25, 2013 at 14:49:17:
Hi Steve, you did the correct thing but hope you didn't apply to much lube. I used to use a small amount of graphite grease on the balls and then lightly wipe the balls with a rag remove all the visible grease. Were the brake disks glazed? Shiny? Ruff them up with a wire wheel or some coarse sand paper. Also if there is an outer or inner edge on the brake disk, remove the edge as it will ride up on the brake drum and prevent the surface of the disks contacting the metal braking surface. Also make sure the roller grooves are not worn so the rollers don't stick part way up the ramp.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
