Posted by Owen Aaland on June 25, 2013 at 17:16:42 from (216.47.34.248):
In Reply to: brakes posted by stephen roberts on June 25, 2013 at 14:49:17:
New brake disks are available from this site.
When the brake disks get worn you lose mechanical advantage in the linkage causing the brakes to require much more effort to work.
Replacing the brake disks may be enough to get you good brakes but often the other wear surfaces have enough material missing that just new disks doesn't really do the job. When that happens you can usually remove a little material from the mating surface of the drum to compensate for lost material. If you go that route do not throw out the old disks until you make sure that your brakes will work Okay. If you happen to remove too much from the drum you can use one old disks to gain a little more clearance.
The best advice on lubing the internal brake parts is don't do it. Anything other than a dry lubricant will collect the brake dust as the disks wear and will cause problems. I usually use a spray on graphite on the balls and ramps.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
